Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-11-2012, 03:59 PM   #1
drywall & compound
hey all pros , i was wandering on new drywall if you tape
the seams then compound them wont there
be a noticeable seam and protrude through the paint ? like
when you repair a wall you can see the patch .
the tape & compound wont be flat to the wall .
thx for any advice
raspy is offline   Reply With Quote
Old 08-11-2012, 05:02 PM   #2
Super Moderator
drywall & compound
Dry wall is never truly flat like plaster---the butt joints are always proud of the surface---thin wide taping makes that thicker area appear 'flat' but it is an illusion.
sdsester (08-12-2012)
Old 08-12-2012, 06:05 PM   #3
drywall & compound
I have seen "stick on" tape that is supposed to eliminate the step of mudding on the tape. If that is helpful to you? That would take care of one coat and some sanding.
Frank5 is offline   Reply With Quote
Old 08-12-2012, 06:33 PM   #4
sdsester's Avatar
drywall & compound
I like the good old fashioned paper tape. Set it in mud one day. Skim coat it out the next. Sand, prime and paint when it is dry.
Make sure you use a wide knife.
sdsester is offline   Reply With Quote
Drywall Primer cougar01 Painting 10 04-06-2012 07:48 PM
The CELLAR gbwillner Project Showcase 112 02-17-2012 11:00 PM
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 11:11 PM
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 11:21 PM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
