Drywall Compared To Cement Board On Garage Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 09:13 AM   #1
drywall compared to cement board on garage ceiling
I have 1/8 inch cement baord on my ceiling in the garage and need to pass a fire inspection. Is this enough or do i need to hang 5/8 lid on top of it?
Goob is offline   Reply With Quote
Old 04-04-2011, 10:03 AM   #2
Rewards Points: 3,130
Can't answer your question, though I suspect my guess would be correct. Are you sure what's up there is cement board? That's awfully thin.
Old 04-04-2011, 06:15 PM   #3
Rewards Points: 29
Whether it would pass inspection would depend on what Code you are under and if the garage is attached or not. Also if the wall to the house above the ceiling has proper fire separation or not.
I also doubt it is cement board. That would be a very odd install.
MarkusAIC is offline   Reply With Quote
Old 04-04-2011, 11:00 PM   #4
Registered User
Rewards Points: 5,498
Welcome to the forum! As said, check with your local B.D. or Fire Marshal. Here is the basics, pp4; http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Gary
Old 04-05-2011, 03:57 PM   #5
our code in ohio is 3/4 sheetrock on ceilings and party walls fire tape
fire tape is just makeing sure that every gap is coverd with mud and tape so no air can pass thru
some places mostly apartment or commercial will have you double up your party walls
i also doubt that you have concrete board on ceiling but this may have been a feeble attempt from a ill advised diy er i hope this helped
lrobertstoner is offline   Reply With Quote
Cement Board Install Vica Building & Construction 5 01-27-2011 07:24 PM
Drywall Ceiling in the garage VinceA Drywall & Plaster 5 09-20-2010 05:22 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
