Drywall/cementboard Joint - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 08:09 PM   #1
Rewards Points: 1,062
Question
drywall/cementboard joint
is it necessary to tape and mud a drywall/cementboard joint on a wall that is 1-2" under where the top line of tiles will be?
thanks
Old 05-11-2012, 08:15 PM   #2
Rewards Points: 13,446
I would use webbed tile board tape and thin set.
You did tape all the joints before the tile and waterproof the tile board before the tile, right?
One less place for water to get in.
Old 05-11-2012, 08:37 PM   #3
But Joe, why would i be asking this question if i had set the tile already?
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 09:11 PM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 03:57 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 08:10 PM
