#1 |
Drywall Ceilings
Does anyone know the Prince Georges County,Maryland rules/codes when hanging drywall ceilings? Is it allowed to just glue said ceilings or are you required to screw or nail for additional support!!??.
#2 |
the Musigician
Drywall Ceilings
hi and welcome to the forum.
ceiling drywall has code as to how far apart to space the screws/nails, thickness as pertaining to joist spacing, and also fire-rating. around here it must be 5/8" Fire-X type or special 1/2" for ceilings. i do not think i would trust gluing it alone..... DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Drywall Ceilings
I'm over in Montgomery County... and I'm 90% sure you need to fasten to the studs (why would the code mention the studs if they weren't required)... also, I'm 100% sure I wouldn't be comfortable sitting/standing/being in that room with just construction adhesive holding it up... :0
#4 |
the Musigician
Drywall Ceilings
i hear that.... me neither.
and that stuff takes about a day to set tight.... how are you going to hold it up there for 24 hours? DM
#5 |
Drywall CeilingsThank you for the quick responds DangerMouse,LevyDiy! I am a disabled Vet. Paraplegic and had this house built back in 2006 through the V.A. In January of this month my sprinkler system bursts from freezing up knocking down my ceilings in the master bedroom,two guest bedrooms and the hallway. When the Insurance company's demo crew took down the ceilings they noticed that there were no screws or nails holding the ceilings up just glue! Which means the part's of the house unaffected by the Insulation under sight are also only being held up by glue. I needed to know if this was a legit practice or cutting cost at the espense of the client? Do you know if P.G. County allows such practices? denetar7
#6 |
the Musigician
Drywall Ceilings
never hearda sucha thing...
DM
#7 |
Learning by Doing
Drywall Ceilings
I am so relieved that you are checking up on someone else's work rather than planning to glue a drywall ceiling up. PHEW!. Call your city building office and talk to an inspector re: legitimacy in your county.
If I could only remember to THINK about what I was doing before I did it. |
#8 |
Drywall Ceilings
Pre-fab house?
| Display Modes | |
| Drywall ceiling: Water Damage, looking for advice | dawho1 | Building & Construction | 11 | 09-13-2010 11:05 AM |
| Old ceiling replacement | idsp | General Discussion | 12 | 07-25-2009 11:48 AM |
| Covering Radiant Heat ceilings. | Hockeynews | Remodeling | 3 | 04-10-2009 09:23 AM |
| Good ways to run pegboard up to drywall? | upthemaiden | Drywall & Plaster | 1 | 03-09-2009 02:12 PM |
| Framing and Drywall questions | haysdb | Building & Construction | 5 | 11-04-2005 08:11 AM |
