Drywall Ceiling, How Does One Finish Side Steps Or Racetrack? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 08:25 PM   #1
drywall ceiling, how does one finish side steps or racetrack?
I want to install two layers of drywall along ceiling edge, one 8" and the other 6". I'm wondering how to finish the edges. do you use corner bead? paper tape? or do you cut it very cleanly and let the paint take care of the edges.
Is this refered to or called racetrack?
petenpeg is offline   Reply With Quote
Old 02-06-2010, 08:32 PM   #2
what is the pupose, just visual detailing?
The older I get the better I was
Old 02-06-2010, 08:53 PM   #3
Rewards Points: 256
if your going to spraytexture it you could tape it and keep it clean , but if your going to paint it no texture i would use z bead. u have to get it at a drywall supply place , tamarack , drywall supply, in minnesota. make sure to get 1/2- 5/8 depending on what you use for the race track , also pick up some gyp to gyp screws .. screws that screw into drywall where there is no wood to screw to. its not easy for the novice but its doable if you take your time.
oldrivers is offline   Reply With Quote
Old 02-06-2010, 09:04 PM   #4
King Construction Inc.
tape works the best you can fold it to the corner and dont be afraid to use a few nails it will make your life alot easyer
nking is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 01:39 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Horizontal drywall w/ dropped ceiling ClnlBrahm Drywall & Plaster 2 09-02-2008 01:38 AM
Plaster Ceiling and drywall dprasan Remodeling 6 02-06-2008 12:34 AM
