Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-04-2013, 09:44 PM   #1
drywall the ceiling
I want to replace the old square fiber-ish ceiling in one of my rooms with drywall. It has that 'blow-in' type of insulation laying on top of it. I plan on using 5/8" drywall, screwing into the 24" ceiling joists. I'll be renting a drywall jack. Should I replace the insulation? Other suggestions? Thanks!
HolyCow is offline   Reply With Quote
Old 01-05-2013, 12:08 AM   #2
drywall the ceiling
Why would you think the insulation needs replacing?
You do plan on just drywalling right over the old ceiling tiles. right?
If anything you may need more.
http://www.energystar.gov/index.cfm?...sulation_table
Old 01-05-2013, 12:26 AM   #3
drywall the ceiling
Make sure to get long enough screws
mae-ling is offline   Reply With Quote
Old 01-05-2013, 02:01 AM   #4
drywall the ceiling
fiberish ceiling? make sure its not asbestos?
federer is offline   Reply With Quote
Old 01-05-2013, 11:23 AM   #5
drywall the ceiling
So what if it is? It's being covered up not cut up.
Old 01-05-2013, 11:31 AM   #6
BabsHoney's Avatar
drywall the ceiling
I read that as taking one down to put up another.
Would love clarification from the OP.
BabsHoney is offline   Reply With Quote
The Following User Says Thank You to BabsHoney For This Useful Post:
federer (01-05-2013)
Old 01-05-2013, 11:38 AM   #7
JOATMON
ddawg16's Avatar
drywall the ceiling
Pictures would help
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-05-2013, 03:42 PM   #8
drywall the ceiling
How long of screws should I use for 5/8" drywall?
Here's a photo. I have no idea whether it's asbestos.
My intentions are to remove the existing before installing drywall.
Old 01-05-2013, 11:01 PM   #9
BabsHoney's Avatar
drywall the ceiling
It's my understanding that if it's not the sort of asbestos that flakes off and most definitely not the loose granule kind, then a small amount is manageable with proper safety precautions (covered clothing, masks, gloves, etc).
I would be concerned less about the tiles and more about the loose insulation.
Someone correct me if I'm wrong.
Old 01-05-2013, 11:33 PM   #10
drywall the ceiling
There's no need to remove it you just going to be making a huge mess and take a whole lot longer, mark your rafters with blue tape on the walls and just go right over it. It will add a small amount of insulation value.
I've done it a few times and never had any issues.
I'd use 3" cource thread screws.
Old 01-05-2013, 11:53 PM   #11
drywall the ceiling
those look like just paper tiles. i think you are ok. but i am no expert
Old 01-06-2013, 12:06 AM   #12
cdaniels's Avatar
drywall the ceiling
I agree.No reason to remove the existing ceiling.You can screw the new drywall in right over the squares as long as it's flat.A lot faster,less messy,no asbestos to worry about,and the only difference is your ceiling is 5/8 of an inch lower.
Charlie Daniels painting and repair
cdaniels is online now   Reply With Quote
Old 01-06-2013, 07:57 AM   #13
drywall the ceiling
+1 for going over. There is no advantage to removing and a lot of disadvantage
you will have to get rid of the ones you take down I don't know how big a space but that could be a problem especially if they do contain asbestos, you will have to manage the blown in insulation because it will all fall out. Then re insulate the space above.
Old 01-06-2013, 02:19 PM   #14
drywall the ceiling
If the ceiling is flat leave it up and dw over it
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 01-06-2013, 03:20 PM   #15
the Musigician
DangerMouse's Avatar
drywall the ceiling
Aren't those the type of "paper" tiles that just GLUE up to the EXISTING ceiling? There may just BE 5/8" drywall already UP there!
Pull that loose one down a bit more and check, says I.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
ToolSeeker (01-06-2013)
Tags
ceiling, drywall, insulation
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 01:52 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
