-   -   drywall the ceiling (http://www.diychatroom.com/f101/drywall-ceiling-168273/)
HolyCow 01-04-2013 09:44 PM
drywall the ceiling
I want to replace the old square fiber-ish ceiling in one of my rooms with drywall. It has that 'blow-in' type of insulation laying on top of it. I plan on using 5/8" drywall, screwing into the 24" ceiling joists. I'll be renting a drywall jack. Should I replace the insulation? Other suggestions? Thanks!
joecaption 01-05-2013 12:08 AM
Why would you think the insulation needs replacing?
You do plan on just drywalling right over the old ceiling tiles. right?
If anything you may need more.
http://www.energystar.gov/index.cfm?...sulation_table
mae-ling 01-05-2013 12:26 AM
Make sure to get long enough screws
federer 01-05-2013 02:01 AM
fiberish ceiling? make sure its not asbestos?
joecaption 01-05-2013 11:23 AM
So what if it is? It's being covered up not cut up.
BabsHoney 01-05-2013 11:31 AM
I read that as taking one down to put up another.
Would love clarification from the OP.
ddawg16 01-05-2013 11:38 AM
Pictures would help
HolyCow 01-05-2013 03:42 PM
Clarification
1 Attachment(s)
How long of screws should I use for 5/8" drywall?
Here's a photo. I have no idea whether it's asbestos.
My intentions are to remove the existing before installing drywall.
BabsHoney 01-05-2013 11:01 PM
It's my understanding that if it's not the sort of asbestos that flakes off and most definitely not the loose granule kind, then a small amount is manageable with proper safety precautions (covered clothing, masks, gloves, etc).
I would be concerned less about the tiles and more about the loose insulation.
Someone correct me if I'm wrong.
joecaption 01-05-2013 11:33 PM
There's no need to remove it you just going to be making a huge mess and take a whole lot longer, mark your rafters with blue tape on the walls and just go right over it. It will add a small amount of insulation value.
I've done it a few times and never had any issues.
I'd use 3" cource thread screws.
federer 01-05-2013 11:53 PM
those look like just paper tiles. i think you are ok. but i am no expert
cdaniels 01-06-2013 12:06 AM
I agree.No reason to remove the existing ceiling.You can screw the new drywall in right over the squares as long as it's flat.A lot faster,less messy,no asbestos to worry about,and the only difference is your ceiling is 5/8 of an inch lower.
ToolSeeker 01-06-2013 07:57 AM
+1 for going over. There is no advantage to removing and a lot of disadvantage
you will have to get rid of the ones you take down I don't know how big a space but that could be a problem especially if they do contain asbestos, you will have to manage the blown in insulation because it will all fall out. Then re insulate the space above.
newfie49 01-06-2013 02:19 PM
If the ceiling is flat leave it up and dw over it
DangerMouse 01-06-2013 03:20 PM
Aren't those the type of "paper" tiles that just GLUE up to the EXISTING ceiling? There may just BE 5/8" drywall already UP there!
Pull that loose one down a bit more and check, says I.
DM
