Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-07-2011, 02:34 PM   #1
Drywall on the ceiling
My basement has floor joists above (about 12') and support beams extending throughout the basement about 1.5' below the joists. Because of the HVAC system, I'll need to have a lower ceiling. My question is, how do you "frame out" a ceiling (essentially, dropping the ceiling 2' so I can have something to hang the drywall to)? Do I just buy long pieces of 2x6 or something similar and fasten them to the support beams and the top of the outer walls?
ctote is offline   Reply With Quote
Old 07-07-2011, 09:40 PM   #2
I make love to my walls
You can do a chicago grid which essentially is a thicker gauge grid ceiling similar to a drop acoustical tiled grid and you can fasten your drywall to that. I've done it plenty of times in basements and commercial jobs. After you frame your walls just screw your angle to the studs and hang your mains from the joists. Any drywall supply house carries the system. It's much faster and accurate than furring down the ceiling with framing lumber
Arey85 is offline   Reply With Quote
Old 07-08-2011, 07:07 PM   #3
Also to add....A Chicago ceiling is only 1-5/8" thick so you don't loose a lot of space.
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 01:52 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
