Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-19-2011, 10:46 PM   #1
Drywall between wall and steps
I'm trying to put drywall between my steps to the basement and wall. I'm having difficulties removing the old drywall because its hard to get behind the steps.
So with that being said, I can't just slide a whole sheet in there. I need to cut the sheet so it goes with the steps. I tried a whole sheet but couldn't get it to slide in.
Just wondering if anyone else has had to do this before. If so, any tips?
Thank you
jburchill is offline   Reply With Quote
Ill Effect of heavy block steps on basement wall? smawgunner Building & Construction 8 06-21-2011 11:26 PM
kitchen clean slate bubbler Kitchen & Bath Remodeling 4 10-19-2010 09:01 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 07:22 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
