Drywall Behind Tub? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 09:54 PM   #1
Drywall behind tub?
I ripped out an old tub and the drywall too. Do i need to go to the floor with the drywall or do i need to have it meet flush with the tub lip? I'm not doing tile around the tub, i was planning of putting some sort of wall surrounding. thanks
tyler
tomknox is offline   Reply With Quote
Old 10-17-2010, 11:19 PM   #2
Rewards Points: 256
id guess you dont have room for drywall in those spots . tubs are installed alot of times before drywall goes up cause they are framed tight to the tub flanges so it covers the gap.
if its a jacussi tub with a deck than yeah you can drywall the walls under it.
oldrivers is offline   Reply With Quote
Old 10-23-2010, 04:07 PM   #3
Your tub lip should be flush with the framing so bring the drywall down about 1/4" above the tub.
Polywanna is offline   Reply With Quote
Old 10-23-2010, 05:15 PM   #4
DIY staff
Rewards Points: 7,174
Drywall does not belong in a wet area---use Durrock or a water proof backer--Mike--
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
