Drywall Bathtub Surround - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 05:33 PM   #1
Hi,
I just installed a Sterling Vikrell bathtub. I did not use the clips on the walls, so that I can remove the walls if there is a problem. I know that I am supposed to butt the bathtub flange with the drywall, but not cover it. Then, I am supposed to fill the gap with a lightweight, setting type compound. My question is, if I have a problem and have to remove the walls, how hard is it to remove the setting type compound from the flange, or do I have to destroy the walls?
I know that some people use 1/8" furring under the drywall and cover the flange. I had to shim the walls in some places, so furring would range from 1/8" to 3/8". The furring may be easier; however, the preferred method above seems the better option with my shimming.
Thanks,
David
bb46970 is offline   Reply With Quote
Old 06-21-2011, 05:46 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And what kind of a problem do you anticipate that would cause you to have to remove that thing?
Do you have any idea how many millions of those things have been installed and no one ever thinks about having to remove them?
You are way over-thinking this thing.
XXX
Bathtub Surround mchipser Remodeling 8 09-08-2011 04:27 PM
Bathtub surround. GWEN BENYO Building & Construction 6 02-02-2011 09:26 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
