Drywall Basement Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 06:29 PM   #1
drywall basement wall
quick dumb question to settle an argument with my know it all brother ..finished the ceiling drywall about to start the walls ..do you start with the top sheet or the bottom ..length wise ...with 89 inch ceiling .. thanks
44070dart is offline   Reply With Quote
Old 03-16-2010, 08:16 PM   #2
im no pro, but everything I've learned is that the most common is to start with the top sheet horizontally, then bottom sheet with an offset to the top sheet. That of course applies to 8ft ceilings and 4x8 sheets. 89in is just shy of 8ft, but I'm assuming it'll be done similarly.
also depends on room size, and what configuration would give you least amt of joints.
acerunner is offline   Reply With Quote
Old 03-16-2010, 08:31 PM   #3
not sure top or bottom.. but I don't believe offsetting is correct
Old 03-16-2010, 08:39 PM   #4
DIY staff
Rewards Points: 7,174
Using the longest sheets you can get down the stairs--Always start at the top--stagger your seams.
Just exactly like Acer said! Some times you can use stand up sheets--nice--no butt joints--
Your framing had better be right on the money for stand ups.----Mike----
So---Who wins the bet?????
Old 03-16-2010, 08:44 PM   #5
as oh'mike said, staggered. That's what i meant by offset. I guess i need to work on using the proper lingo.
Old 03-16-2010, 09:41 PM   #6
OK .. didn't know you stagger thought you would want one seam top to bottom ......I won it ... my " big brother " said to put the bottom one up first than you can have the bottom one hold up the top one while you screw it up ..big brothers man it never stops ..and I'm 60
The Following 2 Users Say Thank You to 44070dart For This Useful Post:
drtbk4ever (03-19-2010), oh'mike (03-17-2010)
Old 03-17-2010, 01:50 PM   #7
Drywall contractor
Rewards Points: 1,070
Top sheet first and cut the bottom sheet about 1/2" short (width) and "jack" it up snug to the top sheet. You don't want it sitting directly on the floor, especially concrete as it will "wick" moisture. Stand-ups will work, as stated above, if your framing is correct. If you lay it down, always stagger the butt joints....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-19-2010, 12:14 AM   #8
Drywall is stronger when it's applied horizontally on a wall. It does have a grain. Also, the wrapped edge (along the taper) adds a bit of strength.
I'm just curious about your ceiling board application. Did you hang it perpendicular to the joists? I run into people every day who don't know there is a right way and a wrong way to hang ceilings.
Ron Franck is offline   Reply With Quote
Old 03-19-2010, 10:24 AM   #9
yeah ...mine needs to be horizontal as the wall framing is good but not perfect ..the ceiling is hung properly (perpendicular).. had a good book for this remodel and it showed how also watched diy on line showing ceiling being dry walled (screwed and glued) the book also showed the walls ...but my brother !!
Old 03-19-2010, 04:06 PM   #10
Drywall contractor
AMEN to the glue. I hope you used it. Most don't, but it makes for fewer fasteners which in turn means less chance of nail/screw pops.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Repainting wall in basement color advise Dionysus Interior Decorating 2 12-25-2008 08:17 PM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
