-   -   drywall basement wall (http://www.diychatroom.com/f101/drywall-basement-wall-66962/)
44070dart 03-16-2010 06:29 PM
quick dumb question to settle an argument with my know it all brother ..finished the ceiling drywall about to start the walls ..do you start with the top sheet or the bottom ..length wise ...with 89 inch ceiling .. thanks
acerunner 03-16-2010 08:16 PM
im no pro, but everything I've learned is that the most common is to start with the top sheet horizontally, then bottom sheet with an offset to the top sheet. That of course applies to 8ft ceilings and 4x8 sheets. 89in is just shy of 8ft, but I'm assuming it'll be done similarly.
also depends on room size, and what configuration would give you least amt of joints.
44070dart 03-16-2010 08:31 PM
not sure top or bottom.. but I don't believe offsetting is correct
oh'mike 03-16-2010 08:39 PM
Using the longest sheets you can get down the stairs--Always start at the top--stagger your seams.
Just exactly like Acer said! Some times you can use stand up sheets--nice--no butt joints--
Your framing had better be right on the money for stand ups.----Mike----
So---Who wins the bet?????
acerunner 03-16-2010 08:44 PM
as oh'mike said, staggered. That's what i meant by offset. I guess i need to work on using the proper lingo. :whistling2:
44070dart 03-16-2010 09:41 PM
OK .. didn't know you stagger thought you would want one seam top to bottom ......I won it ... my " big brother " said to put the bottom one up first than you can have the bottom one hold up the top one while you screw it up ..big brothers man it never stops ..and I'm 60
bjbatlanta 03-17-2010 01:50 PM
Top sheet first and cut the bottom sheet about 1/2" short (width) and "jack" it up snug to the top sheet. You don't want it sitting directly on the floor, especially concrete as it will "wick" moisture. Stand-ups will work, as stated above, if your framing is correct. If you lay it down, always stagger the butt joints....
Ron Franck 03-19-2010 12:14 AM
Drywall is stronger when it's applied horizontally on a wall. :thumbsup: It does have a grain. Also, the wrapped edge (along the taper) adds a bit of strength.
I'm just curious about your ceiling board application. Did you hang it perpendicular to the joists? :yes: I run into people every day who don't know there is a right way and a wrong way to hang ceilings. :no:
44070dart 03-19-2010 10:24 AM
yeah ...mine needs to be horizontal as the wall framing is good but not perfect :whistling2:..the ceiling is hung properly (perpendicular).. had a good book for this remodel and it showed how also watched diy on line showing ceiling being dry walled (screwed and glued) the book also showed the walls ...but my brother !! :mad:
bjbatlanta 03-19-2010 04:06 PM
AMEN to the glue. I hope you used it. Most don't, but it makes for fewer fasteners which in turn means less chance of nail/screw pops.
