Drywall A Basement Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 02:34 PM   #1
drywall a basement ceiling
Hello all, I am in the 1st phase of finishing my basement. I am currently working on a bathroom. I am at the point where I have to frame in for the drywall ceiling. I have 10'ceiling but have to build a " finished" ceiling below that to hide the duct work. My plan was to run 2X4 joists on end to span the bathroom about 8'. Will 2x4's 16"oc 8' long be able to support 5/8" drywall ceiling and a heater vent fan? I am also planning to add insulation in the void space to keep noise down. Any other suggestions?
thanks!
stogman is offline   Reply With Quote
Old 03-12-2011, 09:26 PM   #2
drywall ceiling
If possible keep the ceiling height! If the duct is running through part of the ceiling, bulkhead it. Using 1 1/2"x 1 1/2" angle with drywall screws attach one side the other for backing. Assuming bulkhead are not feasible 2x4 16" OC is more than enough to support 5/8" drywall.
finishingtheunf is offline   Reply With Quote
The Following User Says Thank You to finishingtheunf For This Useful Post:
stogman (03-13-2011)
Old 03-14-2011, 05:05 PM   #3
Master of none
Are you using 5/8" board for sound proofing? If not, I prefer 1/2" ceiling board as it is easier to work with and cheaper.
handy andy is offline   Reply With Quote
Old 03-17-2011, 05:43 PM   #4
yes, using 5/8" for sound proofing.
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 11:30 AM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 03:47 PM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 09:21 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 09:20 AM
