Drywall Basement Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 09:29 PM   #1
drywall basement ceiling
I am about to renovate a basement and plan to upgrade the ceiling from a failing drop ceiling to drywall. The entire suite has drywall, for some reason the kitchen and hall area were left as drop ceiling and time has shown them to be inferior.
Ther eis plenty sufficient space for normal height codes and such. What are all the significant factors I need to consider? grade of drywall, stud spacing, placement of access panels, etc?
Dgggless is offline   Reply With Quote
Old 08-07-2010, 01:12 PM   #2
Drywall contractor
Rewards Points: 1,070
A drop ceiling that is properly installed shouldn't be "inferior". I do prefer drywall in residential applications though and use it whenever possible. You can use regular 1/2" drywall on 16" o.c. framing, 5/8" if the spacing is 24" OR if local code requires (check with your local building dept.) In this area, 1/2" is fine for basements, but codes vary widely. You will need access panels for any gas or water shutoffs and drain clean-outs you may need to access in the future. Plastic, pantable panels of varying sizes are available at HD or Lowes. If I only need one access in a room, I usually just use a return air grill and no one is the wiser.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-07-2010, 02:46 PM   #3
Just remember that electrical junctions must be accessable also!
I'm in the process of doing the same job and have had to rewire most of the electrical, to comply with this code requirement.
A dropped ceiling is preferable for basements, as access is available to the junction boxes.
Unfortunately I don't have enough headroom to allow fro a dropped ceiling.
Old 11-14-2010, 10:43 PM   #4
There are several choices of drywall you can use, this will explain enough to make a choice.http://archwayhomerepairns.blogspot....-you-need.html
Everything should be 16" on centre min. and screwed not nailed. Drywall is something that if you haven't done it before takes some homework to do it right. Even a drywaller had to do it the first time with no experience and learn from his mistakes. One thing to remember if you have to hire someone, '' it costs this much to do it $? and this much to do $$$? it if you started it yourself and screwed it up ''
fixit4u is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
