Drywall Basement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 01:17 PM   #1
Tcs
Drywall basement
I'm putting drywall in a basement and I know the green side faces out but I'm not worried about moister from the inside of the basement. My worrie is the moister comming from the block walls behind the drywall so should the green face the block wall which i know would be backwards but thats where the dampness is going to come from.
Tcs is offline   Reply With Quote
Old 11-25-2010, 04:45 PM   #2
Is there no vapor barrier?
Is there framing?
the answer to your question is no don't do that..I believe the green board won't promote mold growth, but it won't stop the moisture problem.
williamwiens is offline   Reply With Quote
Old 11-26-2010, 10:16 AM   #3
Drywall contractor
Rewards Points: 1,070
Green board is not for use as a moisture barrier. If you have that much of a moisture isue you need to address that issue prior to installing your drywall so as to not allow the growth of mold behind the drywall in the stud/furring cavities. (I'm assuming you're not attaching directly to concrete which is a big NO!) That can mean either an appropriate moisture barrier or addressing the issue on the outside of the house where the problem begins (proper waterproofing, drainage,etc.). You never want to hang the drywall backwards. It makes the finishing twice the work as you eliminate the recessed edges and the backing paper is nowhere as smooth as the face paper, requiring "glaze coating" the entire surface to achieve a good finish. If your moisture issues are taken care of, there's no need to go to the extra expense of green board. Regular drywall will work fine.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
How much to drywall my basement?? Estimate bswain06 Off Topic 12 10-07-2008 02:13 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
