Drywall And Baseboards Oh My! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 11:55 AM   #1
Drywall And baseboards oh my!
Hi, I recently moved into a "fixer upper" and my question is... How Do I repair the 4 in gap between the wall and the floor? Not sure if the wall was damaged when baseboard were removed or what. The room I'm working on was originally a garage.
SamanthaDIYgirl is offline   Reply With Quote
Old 08-31-2011, 05:44 PM   #2
m1951mm's Avatar
I have seen many garages where the drywall does not go all the way to the concrete. I would think it is because of keeping the drywall dry, lol, if water gets into the garage. Anyway, why not just add a new baseboard to fill the gap. You could cut strips of drywall to shim out the backside of the baseboard so it will be in the right place. Are you able to see studs below the existing drywall going down to the floor????? or is it concrete??
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
Tom Struble (09-01-2011)
Old 09-11-2011, 05:40 PM   #3
Drywall contractor
Rewards Points: 1,070
Add backing, if necessary, to cover exposed framing and get it flush with the drywall (drywall, plywood, whatever you have available of the proper thickness). There are several different widths of base available to cover the gap.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall issue at baseboard titan7 Drywall & Plaster 3 02-06-2011 12:30 AM
Baseboards before or after skimcoat? BagOfMostlyWate Drywall & Plaster 5 10-23-2010 08:43 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 05:52 PM
Cracking drywall Smiley77 Drywall & Plaster 4 03-10-2009 04:38 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 08:32 AM
