Drywall Attic Tips - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 09:56 PM   #1
Drywall attic tips
I'm working on finishing my attic and I'm looking for some advice on the best way to finish the angled ceiling. The biggest issue I have is the difference in size of the rafters and the hip rafters. I was planning on leaving the hip rafter exposed and hanging from just the regular rafters but that would leave the drywall edge floating. I don't think spacers would work the best with the angles. Any tips with this issue or attic angled ceiling tips in general would be greatly appreciated. Thanks.
http://i.imgur.com/JMEBJZI.jpg
ihniwid is offline   Reply With Quote
Old 02-24-2013, 11:24 PM   #2
Rewards Points: 12,830
First go back and add your location to your profile.
Just go back to the top right where your name is and edit it.
Also take a look at this map on just how much insulation your going to need to fit in there.
http://www.energystar.gov/index.cfm?...sulation_table
Old 02-25-2013, 07:57 AM   #3
I'm in the bottom of zone 5. I had closed cell foam sprayed in and loose fill behind the knee wall. It's the best I can do to still have a usable space. Considering the balsam wood insulation we had before the change is very noticeable. I posted the uninsulated pic to show the rafters to aid in the understanding of my poorly worded question.
Old 02-25-2013, 08:06 AM   #4
DIY staff
Rewards Points: 7,174
You can do as you described----some drywall nailers may be needed---
wood trim can be used to dress up the exposed rafter edges.
Furring down the entire ceiling to match the wider rafters is often the easiest choice----you have two options----
joecaption (02-25-2013)
Old 02-25-2013, 01:15 PM   #5
When bringing the drywall flush with the hip rafter how far can the edge free float? Even with spacing to even the 2x6 and 2x4s the pitch of the roof wont make a flush surface.
Old 02-26-2013, 07:04 AM   #6
DIY staff
6 to 8 inches should be safe---
Old 02-26-2013, 06:58 PM   #7
thanks for the info
The Following User Says Thank You to ihniwid For This Useful Post:
oh'mike (02-26-2013)
Tags
attic , drywall
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 03:26 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
Tips on Painting new drywall and texture titan7 Painting 6 12-14-2010 05:27 PM
Drywall joints cracking and bulging in attic conversion Leroyb86 Drywall & Plaster 10 10-06-2010 02:47 PM
