Drywall Around Tub Enclosure - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 01:39 AM   #1
Rewards Points: 1,092
drywall around tub enclosure
Is this what folks are recommending for drywalling around the top flange of a one-piece fiberglass shower? Do you scratch up the shower flange so the Easysand sticks to it? Yes, there will be a bead of caulking at the bottom of the Easysand, and I guess you should put something along the lip (temporary) to keep the Easysand up off the flange 1/8". ??? Thanks.
Old 10-23-2013, 02:15 AM   #2
Rewards Points: 6,652
You really need to use DensShield or DurRock around that tub, if you are planning on tiling. If not and just planning on putting up Green or Purple Board, you are looking at a real mess in a very short time.
Old 10-23-2013, 09:17 AM   #3
Rewards Points: 13,296
I've only built about 50 bathrooms but I've never done it that way.
I just set the drywall about 1/4" away from the top of the enclosure and use Alex 230 caulking.
Last thing I want to do is to be trying to finish drywall mud that sure to get all over the top of the enclosure. The sanding that close would scratch it.
The enclosure also will expand and contract slightly, where as the dry wall mud will not.
Any moisture resistant drywall will work fine.
When I cut the drywall I make sure the taper is at the top and the cut is toward the enclosure.
Old 10-23-2013, 12:39 PM   #4
thanks
thanks for the replies. when i searched, i saw another thread where this procedure was recommended by a few guys (if i understood correctly). i, too, was concerned about the easysand cracking and not being able to sand it without tear up the shower stall. when i built in '80, i used a/c plywood above and on the sides of the shower enclosure, as i did not trust sheet rock; it's doing fine. i'll talk to the guy i'm helping and see which way he wants to go; ply or moisture-resistant sheet rock.
Old 10-23-2013, 12:55 PM   #5
No way would I be using any plywood around a shower area!
Old 10-23-2013, 05:26 PM   #6
are you worried about warping, or what? mine's been there since '80, and no problems, but i can see warping as a potential problem. thanks.
Old 10-23-2013, 05:50 PM   #7
Rewards Points: 744
*deleted by poster*
Seattle2k is offline   Reply With Quote
Old 10-23-2013, 11:56 PM   #8
Sorry for the confusion. In the title I have "tub", but it is a shower. Duh.
Old 10-24-2013, 12:18 AM   #9
If it is a shower unit with manufactured walls, then just place Green or Purple board above the lip, prep, prime, then paint. If planning on tiling, use DensShield or DurRock. I prefer DensShield because it cuts like Drywall.
Old 10-24-2013, 01:22 AM   #10
roger that. thanks.
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
