Drywall Around Pipe - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 08:56 PM   #1
Rewards Points: 1,062
drywall around pipe
How do i set drywall around an existing pipe/conduit without removing the pipe?
This is ceiling, BTW
Old 06-25-2012, 09:09 PM   #2
DIY staff
Rewards Points: 7,174
Cut the drywall to size for the space---cut out the hole or slot that will fit around the pipe---
then make a V shaped cut from the hole to the edge of the sheet---install the large part of the sheet--add some 1x4 backers to the V--screw in the V shaped patch.
Easy to tape--the V puts the tape out in the open with plenty of room for paper and mudding.
amakarevic (06-25-2012)
Old 06-25-2012, 09:25 PM   #3
thanks sir
The Following User Says Thank You to amakarevic For This Useful Post:
oh'mike (06-25-2012)
How to protect PVC pipe when soldering near it? Studly Plumbing 8 11-21-2011 11:10 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Capping gas pipe and drywall over destroyer427 Building & Construction 2 03-18-2009 01:40 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
