Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-05-2012, 07:06 PM   #1
Drywall around new shower stall
Hello.
I have just installed a Maax shower in the corner of our small bathroom.
Following the manufactures instructions, I pulled the old drywall off the wall attached the enclosure directly to the studs. You can't really see in the photo, but the room's existing drywall is just a few inches away from the enclosure, on each side.
What would be the best way to finish this off? Should I use some kind of concrete board?
Is there some kind of trim that I should use to help the drywall butt up to the enclosure, over the flange?
Is there some special mud I should use?
Thank you all.
Murph.
MurphyMan is offline   Reply With Quote
Old 04-05-2012, 09:06 PM   #2
Super Moderator
I usually add thin wood 'rippers to the studs (made on a table saw) to shim out the near by studs--making it possible to butt the dry wall up to the tub enclosure without a hump.
Adding drywall 'C' channel to the raw edge is an acceptable way to avoid mudding and taping right up against the shower surround.
If you prefer to mud that instead--use Easy Sand powdered drywall mud---it is harder than the bucket mix and will hold up well to the movement of the fiberglass surround.
MurphyMan (04-06-2012)
Old 04-06-2012, 07:24 AM   #3
Originally Posted by oh'mike View Post
7
So, you can actually butt the drywall to the enclosure and then mud that gap? Sounds tricky to my clumsy hand.
Old 04-06-2012, 07:49 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thats standardly how its done. I would suggest using MR (Moisture Resistant) sheetrock. The glass enclosure, that will likely go around the shower unit, should be water tight.
Never-the-less, if you ever develop a leak down the road, the MR will minimize moisture damage.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Old 04-06-2012, 01:21 PM   #5
Drywall contractor
Both of the above replies are correct. You will need to use tape if there's a gap (and there likely will be). Use fiberglass mesh tape with the setting compound oh'mike recommended....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 02:14 PM   #6
FYI- The method BJ is referring to is; "flat taping" and coating.
- Build Well -
Old 04-06-2012, 06:32 PM   #7
Huh?
Where do I use the tape? As an interface between the drywall and the enclosure?
You wouldn't happen to have a photo would you?
Murph
Old 04-06-2012, 07:00 PM   #8
Super Moderator
If your cuts are close--no mesh tape should be needed---If you have a large gap some tape after the first packing of the gap might be good insurance--
Consider sistering another stud along side the enclosure,as a nailer--looks like you need a place to attach the drywall there--Mike---
MurphyMan (04-07-2012)
Old 04-08-2012, 07:08 PM   #9
Will do.
framing a shower stall n2learning Building & Construction 10 04-07-2011 08:34 AM
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 09:54 PM
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 04:31 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
Stall Shower Renovation Rick Bruner General Discussion 11 01-20-2008 07:34 PM
