-   -   Drywall around new shower stall (http://www.diychatroom.com/f101/drywall-around-new-shower-stall-139368/)
MurphyMan 04-05-2012 06:06 PM
1 Attachment(s)
Hello.
I have just installed a Maax shower in the corner of our small bathroom.
Following the manufactures instructions, I pulled the old drywall off the wall attached the enclosure directly to the studs. You can't really see in the photo, but the room's existing drywall is just a few inches away from the enclosure, on each side.
What would be the best way to finish this off? Should I use some kind of concrete board?
Is there some kind of trim that I should use to help the drywall butt up to the enclosure, over the flange?
Is there some special mud I should use?
Thank you all.
Murph.
oh'mike 04-05-2012 08:06 PM
I usually add thin wood 'rippers to the studs (made on a table saw) to shim out the near by studs--making it possible to butt the dry wall up to the tub enclosure without a hump.
Adding drywall 'C' channel to the raw edge is an acceptable way to avoid mudding and taping right up against the shower surround.
If you prefer to mud that instead--use Easy Sand powdered drywall mud---it is harder than the bucket mix and will hold up well to the movement of the fiberglass surround.
MurphyMan 04-06-2012 06:24 AM
Originally Posted by oh'mike (Post 892633)
7
So, you can actually butt the drywall to the enclosure and then mud that gap? Sounds tricky to my clumsy hand.
AtlanticWBConst. 04-06-2012 06:49 AM
Thats standardly how its done. I would suggest using MR (Moisture Resistant) sheetrock. The glass enclosure, that will likely go around the shower unit, should be water tight.
Never-the-less, if you ever develop a leak down the road, the MR will minimize moisture damage.
bjbatlanta 04-06-2012 12:21 PM
Both of the above replies are correct. You will need to use tape if there's a gap (and there likely will be). Use fiberglass mesh tape with the setting compound oh'mike recommended....
AtlanticWBConst. 04-06-2012 01:14 PM
FYI- The method BJ is referring to is; "flat taping" and coating.
MurphyMan 04-06-2012 05:32 PM
Huh? :confused1:
Where do I use the tape? As an interface between the drywall and the enclosure?
You wouldn't happen to have a photo would you?
Murph
oh'mike 04-06-2012 06:00 PM
If your cuts are close--no mesh tape should be needed---If you have a large gap some tape after the first packing of the gap might be good insurance--
Consider sistering another stud along side the enclosure,as a nailer--looks like you need a place to attach the drywall there--Mike---
MurphyMan 04-08-2012 06:08 PM
Will do. :thumbsup:
