Drywall Around Mixing Valve In Shower - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 07:25 AM   #1
Drywall Around Mixing Valve in Shower
Are there any tricks to getting the drywall to fit nicely around the mixing valve in a shower? I'll be using the Schluter Kerdi membrane so that is why I'm going with drywall instead of CBU.
Just not sure the best way to measure the hole so it lines up properly and tightly. Same with the hole for the gooseneck.
Would appreciate any tips.
DaveTile is offline   Reply With Quote
Old 04-15-2011, 07:46 AM   #2
in the kerdi drain kit, there are two pieces that may help with hole size.
There is one piece for the mixing valve and one for the shower spout.
they are flanges with rubber gaskets on them.
I found that (after the fact) I should have cut the holes in the drywall the sizes of these rubber gaskets as once I put on the thinset, the gaskets pushed the membrane outwards creating a hump. I had to cut off the rubber gasket for the shower spout and didn't end up using the once for the mixing valve as it's circular and my cutout was square.
I haven't had a coffee yet so i hope you can understand what I am saying.
williamwiens is offline   Reply With Quote
Old 04-18-2011, 11:23 AM   #3
One more question,
Is it acceptable to drywall around the "gooseneck in two separate pieces?
In other words one around the top of it and a second on the bottom of it.
Old 04-18-2011, 05:43 PM   #4
don't see why not..
Old 04-18-2011, 10:11 PM   #5
firehawkmph's Avatar
Rewards Points: 1,800
Dave,
It really isn't that difficult to accurately measure for your cutouts. Take your time and double check your measurements before cutting your holes. No magic to it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
Can I use a mixing valve for tub/shower in a shower only application? jayp Plumbing 1 01-21-2010 09:37 AM
shower mixing valve mdm101 Plumbing 2 12-12-2009 09:58 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
