Drywall Around Gas Fireplace Vent - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 11:24 AM   #1
Rewards Points: 29
Drywall around gas fireplace vent
I am finishing basement and Im framing for drywall, I came up to the fireplace vent and I was curious what kind of clearence I should have around it so I dont start a fire because from whatI recall that vent does get warm.
Thanks Shawn
Shawnzy is offline   Reply With Quote
Old 11-26-2011, 11:24 AM   #2
Rewards Points: 29
it doesnt look like it from picture but I left 2 inch's on either side of vent stack.
Old 11-29-2011, 09:42 PM   #3
Rewards Points: 252
two inches should be good. I have the same thing in my basement. I don't think it would get hot enough to start a fire. But I am not going to put the drywall right on the vent either.
jburchill is offline   Reply With Quote
Old 11-29-2011, 09:48 PM   #4
Rewards Points: 582
you can check with fireplace maker for wall trim thimble you install 1st.. then drywall up to it looks nice ..seen quite a few...
Old 11-29-2011, 09:53 PM   #5
Rewards Points: 29
Thanks Guys, No I have a 12 by 12 plate decorative plate on the vent that will cover up the area left for clearence around pipe of drywall and make it look good.
Shawn
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Dryer vent against drywall n0c7 HVAC 2 06-29-2011 10:30 AM
Drywall around a fireplace Snookie Drywall & Plaster 1 09-24-2010 06:35 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
