Drywall Around Garage Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 04:32 PM   #1
Solutions (handyman)
Rewards Points: 364
Drywall around garage door
Free standing garage is insulated and has vapour barrier. All the doors are in place, including two single garage doors. To drywall the door wall, should the tracks be loosened and reattached on top of the new drywall or is notching the drywall around the brackets okay?
Mark Harvey is offline   Reply With Quote
Old 03-18-2010, 08:32 PM   #2
jlhaslip's Avatar
Rewards Points: 2,098
Run the drywall next to the door track assemblies.
Usually, I add a 2 x 4 or 2 x 6 to mount the track on and then butt/caulk the board to that.
If you mount the hardware onto the drywall, it may crush over time.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-19-2010, 03:09 PM   #3
Drywall contractor
Rewards Points: 1,070
Yep, normally the drywall is hung, a 2'x6" "frame" goes around the door and the track fastens to the 2"x...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-19-2010, 11:53 PM   #4
Using 2x4's, I attached them to interior side of rough opening. Door hardware mounts on to the 2x4's, then drywall butts up to the side of the 2x4's. Exterior has metal roll flashing wrapped around the 2x framing to protect against the elements.
Ron Franck is offline   Reply With Quote
2 Door Garage to a 1 Door Garage? jpearson311 Carpentry 43 02-20-2010 12:56 PM
Garage Door Opener Help chard General DIY Discussions 5 02-03-2010 05:06 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
stuck garage door stuckdoor General DIY Discussions 7 08-30-2008 03:30 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
