Drywall Around Exterior Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 11:15 AM   #1
drywall around exterior door
I have to replace some interior damaged drywall around my back door. I live in calgary, so during the winter there is the issue of condensation as the cold air comes in when the door is opened as well as snow melting on the floor. Any advice on what kind of drywall I should use? Should I put j-beads on the bottom and sides? http://www.plasticomponents.com/prod...=3&SubCatId=17
Harlan Craig is offline   Reply With Quote
Old 08-06-2011, 01:28 PM   #2
Jackofall1's Avatar
Welcome Harlan Craig, to the best darn DIY'r site on the web.
You say there is a condensation problem from the door being openned, are you sure its from that and not a lack of insulation around the door framing.
If you have covered it all over you should check for insulation missing between the door framing and the wall studs, usually some "Great Stuff" will help out in tight spots.
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 08:46 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
