Drywall Around A Bathtub - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 09:28 PM   #1
drywall around a bathtub
My boyfriend is replacing his tub. So anyhow, it seems off to me. He already has the drywall around it. Um, greenboard I think. Anyhow, where is it supposed to meet up with the tub? He has it right over the lip and the wall slant.
Whipple is offline   Reply With Quote
Old 09-03-2010, 09:43 PM   #2
Can you provide a picture? I am not sure if you are trying to say that he brought the sheetrock over the lip and now there is a slight pushing out of the sheetrock right at the bottom? If this is the case he could use some sheetrock shims that he can staple all the way up to the ceiling to bring everything out that 1/8". Again If you can provide a picture it may be better.
Justin08 is offline   Reply With Quote
Old 09-03-2010, 09:52 PM   #3
Thats exactly what I mean. But I do have pictures now.
This is the link to the facebook account with all of them. but this is the main picture.
Old 09-03-2010, 10:23 PM   #4
What is he putting over the drywall?
Old 09-03-2010, 11:08 PM   #5
Rewards Points: 262
It should be shimmed out so it is flush with the flange then over the top of the flange but gapped 1/8-14 inch above the ledge and silicone caulk in the gap. Is he gluing on a plastic surround? Then that shoild also get a bead of silicone. I hope he is not tiling over the green board. That will fall apart. If he is tiling he needs to replace that green board with cement board or some other product reccommended for tiling.
Jim F is offline   Reply With Quote
Old 09-04-2010, 10:21 AM   #6
He's planning on putting in a surround. Does anyone have pictures of how it's supposed to be properly done? I'm a very visual person, and I have never been able to find pictures of drywall around a tub.
Old 09-05-2010, 10:05 PM   #7
Drywall contractor
Rewards Points: 1,070
The drywall should be 1/2" up off of the tub to prevent water from "wicking" and rotting it. Greenboard is water resistant, not waterproof. It can actually sit on top of the lip if the tub is not tight to the wall. Then run your cement board over the drywall.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
