Drywall Around Arched Window Falling Apart - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 09:45 PM   #1
Drywall around arched window falling apart
My house was built in 2006, but we aren't the first occupants. When we moved in, there were some light cracks around this round (like an arch) topped window. Since we had many other things to fix/repair around the house, it stayed that way for the past 10 months and now, it seems it has gotten worse and the drywall seems to be sagging in the curve of the window opening and the crack is wider. How should I go about repairing it?? I can actually push up on the drywall and push it back into place. Do I have to tear it all out and redo the whole thing?
Thanks for any help/advice. Also, sorry in advance if I posted something incorrectly as I have never posted anything with pics before!
Drywall around arched window falling apart-crack1.jpg   Drywall around arched window falling apart-crack2.jpg
Tethered Cat is offline   Reply With Quote
Old 01-10-2010, 07:22 AM   #2
Remodeling Contractor
yes, remove all this drywall. Seems this window was not structured correctly. Insufficient header and it needs the correct cripple studs around the window to secure the drywall. Remove the drywall and post pictures of the structure.
Whats the longest sheet of drywall you have gotten thru egress window? bkeech Drywall & Plaster 12 02-05-2010 10:32 AM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Arched top window trim jelly Carpentry 5 07-05-2008 03:38 PM
