Drywall Arch Corner Bead - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-27-2009, 04:29 PM   #16
Rewards Points: 150
I hung the rock in our house and had several arches and barrels....same issue. I sent this sketch to a guy on another site (forgot which one). The feedback I got was basically "don't drag the knife tight along the arch bead, leave a small gap so you get a small thickness of mud covering the notches, then take some extra care with the sanding". I still haven't finished all my arches.
steve1234 is offline   Reply With Quote
Old 10-27-2009, 04:58 PM   #17
Drywall contractor
Rewards Points: 1,070
Yeah, but the pic looks like normal mud "shrinkage" where the cuts are in the bead, not the knife hit the notches. The technique described is correct. And use a knife that is wide enough (8") to make sure you span the notches. Hand sanding with a sponge will take care of the rest.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
corner bead for drywall cfarmer Drywall & Plaster 2 04-13-2009 03:20 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 03:25 PM
