Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-08-2009, 08:25 AM   #1
drywall arch corner bead
i have installed the pre notched arched corner bead and have begun the floating.
i am having trouble with filling in the notches of the cornerbead with mud and having a smooth surface.
any tricks/tips?
rustic is offline   Reply With Quote
Old 05-08-2009, 10:49 AM   #2
The "bead" or outside edge needs to be installed proud of the notches. In some cases this will result of a corner less than 90`. If your bead is more than a 90, you are going to have a very difficult time trying to finish the corner out.
Mop in Hand is offline   Reply With Quote
Old 05-08-2009, 10:03 PM   #3
1 of two things are happening , 1 you pushed the bead on to tight, 2 you are using a knife that is to flexible. put a strait edge accross the bead and see if there is some daylight between the bead tabs and the straight edge.
oldrivers is offline   Reply With Quote
Old 05-09-2009, 09:19 AM   #4
thanks for the replies.
i forgot to mention that this is bull nose corner bead.
the notches are cut halfway into the bull nose so i dont understand how to fill it in with mud to make the radius solid like a normal corner bead.
Old 05-16-2009, 06:12 PM   #5
Drywall contractor
Can you post a picture of what you've got so far??
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-20-2009, 09:11 AM   #6
HABSFAN2006's Avatar
I installed a 8 foot section of rounded bullnose metal cornerbead, and found it wasn't working... So I took it off, and cut an extra 1/2" of drywall on both sides, they could not be coming to a perfect 90º angle.
Then, re-installed the bullnose, and everything worked like a charm.
Very easy to mud afterwards... I just figured this out myself, wish they came with instructions... Is this helpful? I'm not sure if I understand your troubles exactly...
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Old 05-20-2009, 09:30 AM   #7
its the stuff they sell at Home Depot or Lowes, they have the regular corner bead and then they have the arch cornerbead which is what im talking about. it has cuts that go perpindicular to the radius every inch or so and they are at least 1/16'' wide.
So when i drag my knife across them it dips in the cuts of the bead.
ill try to post a pic.
Old 05-20-2009, 09:43 AM   #8
now I get it, I can imagine that being hard to mud up, even if you have to sand after, lots of work... The stuff I had did not have that, so did not require mud on the large radius part of the bullnose.
Is it made for bending at large radius?
can you buy regular stuff without those dips?
Old 05-20-2009, 10:01 AM   #9
yes it is made for bending it on archways.
Old 05-20-2009, 10:18 AM   #10
I have not come across this stuff yet, as I have only used straight stuff.
I would say, use straight stuff where you can. They should take back unused lengths of the ones you have. And, where you have to,
just dump mud on it, and let it dry one to two days, then sand by hand for a perfect finish. I don't imagine the radius should be muded too much, it should be feathered up to it, but not on the radius it's self.
Let it dry hard hard, then sand for a perfect finish.
Please post pictures when available,
good luck with this project.
Old 05-21-2009, 09:22 AM   #11
I would buy some 45 minute drywall powder that you mix in a bucket with water. It dries harder and can probably fill these notches better. I would mix a batch up and take a 6 inch knife and apply the mud with the 6" side of the knife parallel to the corner bead and drag the knife towards the wall. Try to fill these voids with this mud so it will give you a better base for when you run your knife perpendicular to the corner bead to feather it out. I know that you can fill smaller gaps in drywall with this mud and hopefully it will do the same thing in your situation. I would think 1 or 2 coats of this would give you a pretty flat surface to feather out. One thing I would not do(from experience) is just put a bunch of mud on and then try to sand it smooth, not fun and hard to get it smooth by sanding a big glob of mud.
ponch37300 is offline   Reply With Quote
Old 05-21-2009, 09:33 AM   #12
Our guys use the quick dry plaster to do the initial fill of the arch corner bead. It's a lot harder than drywall compoint.
They mix it a little thick so it doesn't settle and fall through the holes.
They just put it on thick enough to fill the holes then, once hardened, they go over it with regular drywall mud.
It always turns out well and we haven't had to go back and fix any.
KHouse75 is offline   Reply With Quote
Old 10-26-2009, 04:25 PM   #13
http://www.diychatroom.com/attachmen...1&d=1256588628
i know its been awhile but can someone tell me what i should do with this.
im pretty sure i need to add mud to this but do i do it with the fast mud that some of you are suggesting. ( i have already filled it with green mud)
what could i use to sand it with?
Old 10-26-2009, 04:42 PM   #14
The picture isn't very clear, and i'm not sure of the angle.
Can you post a different angle, or a high res picture?
Old 10-26-2009, 06:07 PM   #15
Drywall contractor
You can use either type of mud. The setting type doesn't shrink as much which may save you another coat. Sand with a sanding "sponge".....
corner bead for drywall cfarmer Drywall & Plaster 2 04-13-2009 04:20 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
