Drywall Arch - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 10:16 AM   #1
Drywall arch
I would like to build an 8 feet span arch in a master bath. I'll attach 2 x4 studs on the side walls to support the top plate (2x4) on the ends. The top plate will span about 8 feet across. The problem is the joists supporting the drywall ceiling run in the same direction as the top plate.--As a result, there is no solid wood above the drywall ceiling where I can screw/nail the top plate to. I was thinking of using hollow wall toggle bolt anchors to secure the top plate to the ceiling. What's your opinion? How close should I space the toggle bolts? Will the ceiling drywall alone be strong enough to support the arch?
After the top plate is attached, I would attach 1/2 inch OSB and then 1/4 inch drywall to finish off the arch.
Any and all opinions would be welcome!
billyg is offline   Reply With Quote
Old 09-21-2011, 10:53 AM   #2
Rewards Points: 150
Block between the existing ceiling joists and nail the top plate to those.
Around here, the guys will drywall the the walls but the actual arch is made from 1/8" tempered hardboard. They tape and float it, texture it and paint it. Looks like it works since this has pretty much been the standard for several decades.
TrapperL is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
