-   -   Drywall Anchor Issue (http://www.diychatroom.com/f101/drywall-anchor-issue-163118/)
tcharleschapman 11-12-2012 02:38 PM
So this is a simple issue that came up while installing a new toilet paper dispenser. I was re-installing the new anchors and screws when one of them went right through the dry wall. I found a larger anchor, but it is not snug so one side wobbles around. I know it will fall off eventually so I what can I do to repair this small part of the wall so it is solid enough to use another anchor on?
jcarlilesiu 11-12-2012 02:43 PM
Use a plastic expansion anchor in the drywall before inserting the screw.
You basically drill a hole slightly smaller than the expansion sleeve, push it snuggly into the hole, and then fasten the screw into it. The plastic expansion sleeve will expand when the screw goes into it, and snug everything up in the opening.
They make more heavy duty ones, but for a toilet paper dispensor, something like this should work fine.
http://www.naturalhandyman.com/iip/i...i/plastic1.jpg
Canarywood1 11-12-2012 05:22 PM
Get a small package of these,much better than the other type.
http://www.mrgrabbar.com/TOGGLER-Hol...4532_a_7c11010
Hardwood Head 11-12-2012 05:27 PM
Use a toggle bolt, they are the strongest drywall anchor in my opinion and as you already have a larger hole this would be a simple soluton.
sdsester 11-12-2012 05:48 PM
First before I forget, let me caution you to be careful with simple things like towel rack and toilet paper holders. I cannot remember all the times I have encountered a mystery leak putting a pinhole in copper plumbing installing such things.
Sadly, if your anchor is not biting into the drywall because it is too loose for the hole you made, your situation will get worse over time as it works around and abrades the drywall.
It sounds like you now have a hole too large for the plastic anchors shown. A metal expansion anchor might work. As suggested a butterfly toggle is a possibility unless your bracket calls for two screws. You will not have room for two. A butterfly has wings that fold as you slide it through the hole and that unfold when clear on the other side. You then draw up the bolt to cinch the fastener. Overkill for mounting a toilet paper dispenser but not much else will work on a large hole. There are all sorts of hybrid variations:
http://www.renovation-headquarters.c...uping%20cr.jpghttp://0.tqn.com/d/homerepair/1/0/F/...lon_toggle.jpg
http://img2-2.timeinc.net/toh/i/askt...ll-anchors.jpg
To be honest though, if you have problems with the toggles you may have to cut out a small piece of drywall, secure some blocking for a patch and for the mounting bracket. Tape, mud, prime and paint.
You can patch the hole with dry mud but it wil not be strong enough for plastic screw anchors and screws.
I am sure it is of minimal comfort but this happens more often than you might think so do not be too hard on yourself. I have used thousands of drywall anchors of different kinds hanging art for galleries over the years and every once in awhile the situation got away from me in a hurry. All you can do is curse briefly and move on!
MarkusAIC 11-12-2012 10:24 PM
Use one of the anchors sdsester posted. DO NOT use the plastic ones jcar posted. They do not work well in drywall at all. Great in tile or masonry, crap in drywall.
jcarlilesiu 11-19-2012 12:48 PM
I agree they are not the best... but I have used the cheap expansion anchors all over my house with very little problems.
The toggle kind are a little more tricky to get installed, and clearly for a DIY who is having this level of problems, the less complicated the better. Plus, we are talking about a toilet paper dispenser, not a flat panel TV.
Absolutes, like "do not work", is rarely accurate.
