Drywall & Metal Studs. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 11:16 AM   #1
Drywall & metal studs.
Can you remove drywall from metal studs without damaging the studs?
meow571 is offline   Reply With Quote
Old 11-05-2010, 05:59 PM   #2
Thumbs up
yes
yes, with a little care... not with a sledge hammer.
cut perimeter of area to be removed... cut into small sections ... remove gently with care... you may want to score at stud locations. Remove screws with drill-motor and proper bit. small area to be removed at a time should be under on center of studs.
Big Bob is offline   Reply With Quote
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 09:59 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
sub panel metal studs donaldbyrd Electrical 4 01-25-2008 04:50 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 04:31 PM
Penetrating Metal Studs gbarron1 Building & Construction 12 03-18-2005 11:13 PM
