Drywall Adhesive Spray - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 10:30 PM   #1
drywall adhesive spray
what is best drywall transition bullnose spray?
hoolehuatita is offline   Reply With Quote
Old 02-24-2013, 10:43 PM   #2
Rewards Points: 14,312
I guess you really mean outside corner bead.
http://solutions.3m.com/wps/portal/3...=1114288591719
Old 02-24-2013, 11:03 PM   #3
It's so easy to avoid using a toxic spray adhesive here. I try to be safe even when it's not easy, and to see a spray marketed for something like this...
I'd use a nail on or paper faced bead. If I had to glue I'd use polyurethane caulk or something else that's not sprayed.
Dorado is offline   Reply With Quote
Old 02-25-2013, 05:38 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
I use adhesive spray and plastic bead when the framing is steel. Only time I'll use the paper/metal bead is on outside corners other than 90*.
Havent killed a customer yet.
12penny is offline   Reply With Quote
Old 02-25-2013, 08:03 AM   #5
I was thinking caulk would be unusual but it just occurred to me that caulk or constructive adhesive may be my only options because this is the bead I bought and nailing would warp it:
Old 02-25-2013, 09:21 AM   #6
Rewards Points: 243
I've used 3M, and found it too unforgiving. I'm currently using Loctite 200 "middle" spray and it is working well. Spray both the wall and the inside of the bead and don't wait to apply the bead to the wall. If you wait then the adhesive grabs hard and won't let go, so unless you got the bead in the right spot on the first try you are going to rip the paper to get it back up. With the adhesive fresh the bead will side around a bit so you can get it just right. Then I let it dry overnight and set the mud flange in hot mud. Good luck.
chemman is offline   Reply With Quote
Drywall Adhesive RMCarner Drywall & Plaster 0 05-16-2011 08:38 AM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Spray Texture for Drywall... greylockwood Drywall & Plaster 3 05-18-2010 11:29 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
