Drywall Above Shower? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 04:15 PM   #1
Rewards Points: 12
Drywall above shower?
I am putting a shower in my basement and would like to know what kind of drywall is used above/around the shower (3 piece acrylic type shower). Was planning on using 1/2" paperless, priming it, and a couple coats of good paint.
Thanks in advance for your input.
natspawpaw is offline   Reply With Quote
Old 01-24-2013, 05:56 PM   #2
Rewards Points: 13,276
What's the joist spacing?
Old 01-24-2013, 07:33 PM   #3
funfool's Avatar
Rewards Points: 534
1/2" will be fine, many will suggest 5/8" on the lid so it will not sag.
I never use 5/8 for the lid, Have not had any problems with 1/2". As a remodel carpenter for many years, I rarely find 5/8" except for fire wall in garage and would also be 5/8 on garage ceiling if living space above it. 5/8" has a purpose.
And the average truss built roof, the rafters are set 24" apart and ceiling below it has 1/2" drywall on it.
Since you are in a basement, you have floor joist as your ceiling, and probably 16" oc,
Either way, your plan sounds fine.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
princelake (01-24-2013)
Old 01-28-2013, 01:58 AM   #4
Rewards Points: 1,092
"the standard" around here is 5/8 on the lid, if 24" OC. if i could recall what we used in '80 on my house, i'd voice an opinion, but i can't (i think it was 1/2", though). i will use 5/8 on my new house, and am using 5/8 on my shop. some guys on another forum recommend 5/8 anywhere there is 24" OC wood; walls or ceiling. 5/8 is sure safer, as far as sagging. primer and good paint is what we did; works fine, but we don't take long, steaming showers. some folks do, and sheetrock may not be the best choice there.
Old 02-04-2013, 08:52 AM   #5
Rewards Points: 626
any thing 24" OC requires by code 5/8 sheetrock and that is wall and ceilings. yes you may not have problems. but your customer might down the road will have them.
Nailbags is offline   Reply With Quote
Old 02-04-2013, 05:39 PM   #6
Registered User
Rewards Points: 5,216
You are going to need to finish the drywall joints, per code, 1/2" "ceiling board" is stiffer and will span the 24" (footnote "d"); http://publicecodes.cyberregs.com/ic...002_par010.htm
The local AHJ will probably allow any of the newer "lightweight" 1/2" boards, with a water-based texture and insulation above equal to 5/8" standard drywall. They have equivalent sag-resistance; http://www.americangypsum.com/data/p...alsheet541.pdf
http://www.usg.com/sheetrock-ultrali...um-panels.html
http://www.certainteed.com/products/...-boards/341275
http://www.gp.com/build/toughrock-lightweight-drywall
Gary
Cement board over drywall during vinyl shower pan install asc12 Tiling, ceramics, marble 6 02-25-2012 08:19 AM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 10:40 PM
Finishing drywall around one piece shower stall jonesbill Drywall & Plaster 5 08-14-2011 09:29 PM
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 04:31 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
