-   -   Drywall above shower? (http://www.diychatroom.com/f101/drywall-above-shower-170011/)
natspawpaw 01-24-2013 03:15 PM
I am putting a shower in my basement and would like to know what kind of drywall is used above/around the shower (3 piece acrylic type shower). Was planning on using 1/2" paperless, priming it, and a couple coats of good paint.
Thanks in advance for your input.
joecaption 01-24-2013 04:56 PM
What's the joist spacing?
funfool 01-24-2013 06:33 PM
1/2" will be fine, many will suggest 5/8" on the lid so it will not sag.
I never use 5/8 for the lid, Have not had any problems with 1/2". As a remodel carpenter for many years, I rarely find 5/8" except for fire wall in garage and would also be 5/8 on garage ceiling if living space above it. 5/8" has a purpose.
And the average truss built roof, the rafters are set 24" apart and ceiling below it has 1/2" drywall on it.
Since you are in a basement, you have floor joist as your ceiling, and probably 16" oc,
Either way, your plan sounds fine.
jklingel 01-28-2013 12:58 AM
"the standard" around here is 5/8 on the lid, if 24" OC. if i could recall what we used in '80 on my house, i'd voice an opinion, but i can't (i think it was 1/2", though). i will use 5/8 on my new house, and am using 5/8 on my shop. some guys on another forum recommend 5/8 anywhere there is 24" OC wood; walls or ceiling. 5/8 is sure safer, as far as sagging. primer and good paint is what we did; works fine, but we don't take long, steaming showers. some folks do, and sheetrock may not be the best choice there.
Nailbags 02-04-2013 07:52 AM
any thing 24" OC requires by code 5/8 sheetrock and that is wall and ceilings. yes you may not have problems. but your customer might down the road will have them.
Gary in WA 02-04-2013 04:39 PM
You are going to need to finish the drywall joints, per code, 1/2" "ceiling board" is stiffer and will span the 24" (footnote "d"); http://publicecodes.cyberregs.com/ic...002_par010.htm
The local AHJ will probably allow any of the newer "lightweight" 1/2" boards, with a water-based texture and insulation above equal to 5/8" standard drywall. They have equivalent sag-resistance; http://www.americangypsum.com/data/p...alsheet541.pdf
http://www.usg.com/sheetrock-ultrali...um-panels.html
http://www.certainteed.com/products/...-boards/341275
http://www.gp.com/build/toughrock-lightweight-drywall
Gary
