Drywall Above Fiberglass Surround - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 02:03 PM   #1
Amateuralex's Avatar
Rewards Points: 270
drywall above fiberglass surround
OK, I am sure that this is an old question, but I've searched some and not seen a good specific answer, so I am asking again!
We have a 3-piece fiberglass surround. Right now, there's tile above it to the ceiling, but we're tearing that out. It gets fairly wet during showers, despite it being so high on the wall.
Can I use drywall there? Greenboard? Or should I use cement board? Will cement board beside greenboard (that is used outside of the shower stall) have the same texture and not look different when finished?
Amateuralex is offline   Reply With Quote
Old 04-22-2013, 06:23 PM   #2
Rewards Points: 12,802
Use green or purple board, no need for tile board.
Amateuralex (04-26-2013)
Old 04-22-2013, 06:28 PM   #3
Rewards Points: 528
No Joe. Cement board is used if it is getting wet. Drywall is not to be used.
OP, cement board finishes like regular drywall.
framer52 is offline   Reply With Quote
Old 04-22-2013, 07:34 PM   #4
Since when?
Tile board is not waterproof, so what good would do?
I've never once seen tile board used above an enclosure.
http://www.gp.com/build/densshield-tilebacker-board#
Old 04-26-2013, 08:31 AM   #5
Rewards Points: 270
Thanks!
Old 05-01-2013, 10:07 AM   #6
Rewards Points: 119
Can you show some pictures of finished cement board? I do not see how it would finish the same.
KStatefan is offline   Reply With Quote
Old 05-01-2013, 10:29 AM   #7
Cement board isn't supposed to get wet. That's why tile goes over it.
jsbuilders is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
What product to use to fill in gap between drywall and shower surround RobertN Drywall & Plaster 3 09-09-2010 06:32 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Tiling stub surround -- my detailed plan 99miles Remodeling 1 08-17-2009 05:55 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
