Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-16-2010, 10:44 AM   #1
Advertising Photographer
Drywall
I recently pulled off the vinyl 12"x12" backsplashes in my kitchen. Some of the pieces came off easy, but the glue from others pulled off what looks to be the top layer of drywall. Is there a way to smooth out the wall myself? Or should I hire someone to spray texture it?
greylockwood is offline   Reply With Quote
Old 02-16-2010, 12:43 PM   #2
sdsester's Avatar
Drywall
You should plan on replacing the drywall if that much is pulled away, especially in the kitchen. Even if you could fix it, it will be cheaper to just start over.
What are your plans for new backsplashes? Real glass or ceramic tile or just paint? You will want a backer board if tile or just about anything else is in your future.
sdsester is offline   Reply With Quote
Old 02-16-2010, 01:12 PM   #3
Drywall
Do not try and mask this with texture.
I think a skim coat is a DIY friendly project.
Get a bucket of premixed drywall compound and a drywall knife. An 8 incher should work fine. Skim a light layer of compound across the rough spots, then sand it smooth. Shine a bright work light across the surface and it will show you the spots you missed.
This will be dusty, so tape down plastic over everything and wear a respirator.
Pick up a foam sanding block to make the sanding easier:
http://www.seven1seven.com/images/Trim-Tex_sponge.JPG
Dairylander is offline   Reply With Quote
Old 02-16-2010, 01:17 PM   #4
jlhaslip's Avatar
Drywall
what dairylander said.
might take several coats to get smooth.
for finisher sanding a lightly damp sponge works good.
prime and 2 coats of finish colour.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-16-2010, 01:19 PM   #5
sdsester's Avatar
Drywall
I guess I should ask what you mean by top layer of drywall? Did you loose some of the paper or is 1/4" missing from 1/2" or 5/8" stuff? Cannot skim coat that much missing. You might get by skim coating where the paper used to be. I still wouldn't do it in a kitchen.
Old 02-16-2010, 01:43 PM   #6
Military Mom of 4
Snav's Avatar
Drywall
If you're going to tile your back splash area then you'll have to put up backer-board which can just go over top the molested drywall.
You only need to repair it if you're going to paint it.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-16-2010, 03:21 PM   #7
Drywall
Post a picture of the situation. I had some severe damage when i removed some wall paper. I had to do 2-3 skim coats and a little sanding. But i only painted. You need some strength so tiling on top of extensive skim coating may create a reliability risk.
beerdog is offline   Reply With Quote
Old 02-16-2010, 04:06 PM   #8
Drywall
I've patched and skimmed the whole surface and it looks great. I'm going to sand and paint, no tiling. Thanks for everyone's help on the matter....
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
