Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 09:18 AM   #1
Drywall
When finished sanding drywall what is the best way to wipe the powder off the sheetrock
Budrok@Aol.com is offline   Reply With Quote
Old 09-03-2009, 10:01 AM   #2
Old School
Willie T's Avatar
A moist sponge.
Willie T
Old 09-03-2009, 11:29 AM   #3
Registered User
Termite's Avatar
To elaborate, a BIG moist sponge. Not wet, moist. Keep a bucket of water close and wring it out before applying to the walls.
A tip:
Keep your strokes with the sponge going only in one direction. When you sand your drywall, the paper face's paper fibers are raised somewhat. A moist sponge will cause them to lay back down flat, and you don't want them going in multiple directions. It won't always make a difference (depending on the paint thickness and texture) but it is a good habit to get into just in case.
Old 09-03-2009, 11:55 AM   #4
Remodeler
adpanko's Avatar
Rewards Points: 150
I absolutely hate finishing drywall, and the clean-up is a large reason why. But anyway, I tackle it in two steps:
1) I vacuum off the walls with my shop vac with the wide brush attachment. Or, if I don't care about making a mess, I sweep the walls downward with a normal broom to get the bulk of the dust to the floor. The pleated filter on the shop vac packs up pretty quick with the dust and makes the suction really weak after about two standard sized walls. So I find that I have to shake the filter out about twice per room. Then after the vacuuming or brushing is done...
2) I use an old tee shirt or terry cloth dish towel and soak it with water, then wring it out REALLY well, and use that to give the walls a final once over to pick up whatever the vacuuming or sweeping didn't get.
If you don't vacuum or brush the bulk of the dust off first, I find that using a moist sponge or towel to get the dust off gunks up too quickly to the point that you have to rinse it a prohibitive amount of times.
adpanko is offline   Reply With Quote
Old 09-03-2009, 03:06 PM   #5
Thanks everyone. Now it looks like the hard part. (Cleaning Up)
Old 09-08-2009, 03:56 PM   #6
Drywall contractor
Rewards Points: 1,070
I've never actually done it, but I've seen painters use a damp sponge mop. Gives you a handle and a longer reach....
(And I should mention I sand with a sander with a vacuum attachment, so not much need to wipe down.)
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
