Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-17-2008, 09:03 AM   #1
Drywall 4x8 or 4x12?
I'm going to drywall my basement and would it be more beneficial to use 4x12 sheets of drywall or 4x8 sheets? Thanks everyone
SnowUtopia is offline   Reply With Quote
Old 06-17-2008, 09:07 AM   #2
A "Handy Husband"
rjniles's Avatar
Usually 4 by 12 sheet are better because you will have less butt joints to tape, but it depends on the shape of the room. But consider 4 by 12 will be harder (or impossible ) to get into a basement.
rjniles is offline   Reply With Quote
Old 06-17-2008, 09:09 AM   #3
That's exactly what I was thinking too - 4x12's would be better and more cost effective for the compound and joints but pretty hard to work with and get around in a basement.
Old 06-17-2008, 09:51 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The big question is: Do you have a walk-out basement or a basement that you will have to access from a bulkhead.
Generally, the pros will use 4x12 sheets to reduce the number of seams. However, for a newbi, such sized sheets can be difficult to handle, due to their size and weight. As stated, the other concern is access to the basement.
Walkout: You can get 4x12's in
Bulkhead: 4x10's will just squeeze in.
Other (smaller access points):4x8's will be the size to get.
- Build Well -
Old 06-17-2008, 09:53 AM   #5
Atlantic - thank you very much. I have a walk out basement so I could bring the 4x12's in through the door. I will have someone helping me hanging so I might just go with the 4x12's. Thanks.
Old 06-17-2008, 10:20 AM   #6
FWIW: 4x12' onto walls is not that difficult.
4x12's to attach to the ceiling done manually (without a lift, or other supports) is a world of pain for a newbi. They are extremely heavy, and most people, unless they work out with weights on a regualr basis, have great difficulty holding such weight over their heads, arms extended, for various lengths of time.
- Build Well -
Old 06-17-2008, 11:26 AM   #7
Mechanical Engineer
comp1911's Avatar
T-bar
comp1911 is offline   Reply With Quote
Old 06-17-2008, 01:22 PM   #8
RippySkippy's Avatar
drywall lift!
Don't know where your at...but around here you can rent one for around $40 per weekend, and they break down to fit into a car. Best money spent...makes hanging DW almost easy. By myself I DW'd a 9' high ceiling in my garage with 4x12x5/8" fire rated. It was all I could do to load a single sheet...I couldn't of done it any other way. The pro drywallers wouldn't be caught dead with one...but that's why they're the pro and I'm not.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
Last edited by RippySkippy; 06-17-2008 at 02:11 PM. Reason: wrong size of DW was 4x8x5/8"
RippySkippy is offline   Reply With Quote
Old 06-17-2008, 01:37 PM   #9
Mechanical Engineer
comp1911's Avatar
Originally Posted by RippySkippy View Post
drywall lift!
Don't know where your at...but around here you can rent one for around $40 per weekend, and they break down to fit into a car. Best money spent...makes hanging DW almost easy. By myself I DW'd a 9' high ceiling in my garage with 4x8x5/8" fire rated. It was all I could do to load a single sheet...I couldn't of done it any other way. The pro drywallers wouldn't be caught dead with one...but that's why they're the pro and I'm not.
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
drywall question billyg Drywall & Plaster 3 08-01-2008 10:49 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
