Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 09:12 AM   #1
Drywall
I getting ready to install hot tub and a stand up shower should I take out the regular drywall and put in the mold proof drywall . The drywall there is not finished its part of the new work I done . I just now thought about the mold proof drywall thing . I don't want have any mold problems with the new work . Thank in advance for your advice.
luckybodog is offline   Reply With Quote
Old 06-06-2012, 09:16 AM   #2
Trucon01's Avatar
Rewards Points: 510
You should never use regular drywall in a bathroom / wet area. Either green/blue board or cement board, depending on the application...
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 06-07-2012, 12:32 AM   #3
Rewards Points: 1,092
x2 on that. no drywall.
Old 06-07-2012, 01:14 AM   #4
Rewards Points: 626
No sheet rock is mold proof it is mold resistant. And if humidity gets behind the sheet rock then you will have mold problem!
Nailbags is offline   Reply With Quote
Old 06-07-2012, 06:34 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use only cement board in areas such as shower and tub enclosures. DO NOT use ANY kind of sheetrock, unless it is water proofed in some way.
- Build Well -
Old 06-07-2012, 05:20 PM   #6
An old Tradesmen
Rewards Points: 6,516
Moved to drywall and Plaster forum.
Old 06-08-2012, 12:43 AM   #7
Registered User
Rewards Points: 5,216
No greenboard in wet areas, no vapor retarder behind it, no 24" o.c. ceiling framing; http://publicecodes.citation.com/ico...002_par014.htm
http://publicecodes.citation.com/ico...002_par013.htm
Gary
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
