Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 09:32 PM   #1
drywall
i want to hang drywall over plaster walls, do i need to put on furring strips first then hang the drywall to that?
megryan4986 is offline   Reply With Quote
Old 03-17-2012, 09:38 PM   #2
Rewards Points: 13,300
Was the plaster installed after the baseboards went up? Should be able to tell by looking at the tops of the baseboards, it should be at least 3/4" showing.
How thick a drywall do you plan on using?
Has there every been insulation added in the walls?
Has the wiring been up graded?
Plan on leaving the trim on around the windows and doors?
If so post a picture of the trim.
And yes there's a good reason I'm asking.
Old 03-17-2012, 09:55 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You don't need to install furring strips. You can install the sheetrock (overlaid) directly onto the plaster. Just make sure that your screws are long enough to pass thru the plaster and insert at least 3/4" into the framing.
Realize that you are adding thickness to your walls and other areas will be affected, such as door/window jambs, electrical outlets/switch plates, and some other points. So you will have to furr out the trim and use spacers with the electrical.
- Build Well -
Old 03-18-2012, 05:41 PM   #4
If you going with drywall directly to the plaster then use drywall adhesive not just screws, The base boards and all the trim needs to be removed around doors and windows. Your going to have to use jamb extentions unless you go with 1/4 drywall and cut it so it's almost to the outside edges of where the trim covers.
Old 03-18-2012, 10:44 PM   #5
Tip: If you have plaster surface lumps or loose plaster sections, you can remove the areas and use a proper thickness (corresponding thickness) sheetrock to fill-in the locations.
There is also a benefit of using 3/8" sheetrock over 1/4" sheetrock (on certain projects). On some surfaces, 3/8" will generally layer "flatter" while 1/4" will follow irregular contours (if there are any present). So you should select the best (suitable) sheetrock thickness for the renovation conditions.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Willie T (03-19-2012)
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
