Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 04:52 PM   #1
Drywall
How much sheet-rook do I need for a 2600 sqf home
Brian7631 is offline   Reply With Quote
Old 04-25-2011, 05:06 PM   #2
Old School
Willie T's Avatar
If it's very short and has no rooms inside...... not a whole lot.
Willie T
Old 04-25-2011, 06:57 PM   #3
Handyman
Rewards Points: 512
You go me beat Willie..never installed sheet-rook!
Seriously to the OP..thats like asking how much wire do I need for electrical, or how much copper is required for plumbing.
canadaclub is offline   Reply With Quote
Old 04-25-2011, 07:02 PM   #4
DIY staff
Rewards Points: 7,174
That depends on the number of rooms---height of the walls and the size of the sheets of drywall.
We need more info---post a set of prints---I'll do a take off for you.---Mike---
Old 04-25-2011, 07:08 PM   #5
Rewards Points: 5,336
You're kidding aren't you?
Do you think that the houses design might be a factor.
Look at the plans and figure it out if the architect didn't do a material list.
Or contact him and have him generate one.
Ron
Old 04-25-2011, 07:17 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How much sheet-rook
More than pawn's paulty salary and less than a king's ransom.
XXX
Old 04-25-2011, 07:22 PM   #7
Registered User
Rewards Points: 4,944
Welcome to the forum! Please only post one thread for one subject, makes our job easier, thank you...
Gary
Old 04-25-2011, 07:26 PM   #8
DIY staff
Sorry guys----I moved a post from 'Automotive" and answered it----another MOD must have merged the two or three posts---
Obviously the fellow needs an answer--RIGHT NOW---
So I say ,' Get one really big sheet of drywall,say 35 feet wide by 60 feet long and cut to size.
Old 04-25-2011, 07:26 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Something is amiss with the board.
My above comment (Post # 7) was meant to give oh-mike some crap when his post (answer) was all that appeared in the thread.
I just tried to go back to my Post #7 and edit it a little and I can't get in.
Jheeeeezh! Now, what was my Post # 7 has been removed and #7 now belongs to another comment. I give up.
XXX
Old 04-25-2011, 07:35 PM   #10
DIY staff
Gary moved the post to the new "Twilight Zone" section,Bud.
Danger can turn your post upside down if you like---He keeps the fun tricks like that a secret.--Mike--
Old 04-28-2011, 01:46 AM   #11
you should be fine with 3 sheets, possibly 4 if you have high ceilings
chrisBC is offline   Reply With Quote
Old 05-01-2011, 03:14 PM   #12
You most likely need about 10,000 square feet of drywall. You don't calculate drywall by the sheet, you calculate it by the square foot.
dberladyn is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
