Dryvit Or Stucco? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 12:18 PM   #1
RoughLanding's Avatar
Dryvit or Stucco?
So, one of the ladies at my church has a modular home that has some sort of weird siding. There are holes in it, and it's causing heat to escape from under the house. I think it's either Dryvit or Stucco.
I'm not looking to do a perfect repair job, just one that looks decent at a distance(I don't want to spend more than 2-3 hours on this).
She had a cat get stuck up under there as well, so it does need patching.
RoughLanding is offline   Reply With Quote
Old 12-22-2012, 11:02 PM   #2
automated tool pro
Rewards Points: 152
what that is is a mess. and it needs to be removed and done right. I think there are better underpinning systems than a stucco. brick is one of them.
drywallfinisher is offline   Reply With Quote
Old 12-23-2012, 07:10 AM   #3
Rewards Points: 13,270
I agree 100% that was doomed to failure, never should have been done that way.
Old 12-23-2012, 10:31 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
i agree with those above. however, if you simply want to patch this for your friend? you can tie chicken wire behind the rabbit wire that's there and use sakrete mortar mix and trowel it on the holes, use a rubber trowel to smooth it out similar to what's there. don't mix it too thin so will hold onto wire backing. I doubt she's losing heat there, this isn't a conditioned area, though a lot of cold is going under her home. the cats are a separate problem. tie your chicken wire tight and flat as you can. your patches will probably still be there when the rest has frozen thawed over and over and popped off
good luck
Larry/coupe
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
dryvit stucco installation cgp Building & Construction 1 08-22-2011 09:21 AM
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
Dryvit or Stucco over Existing Painted Brick andrew2008 Building & Construction 4 03-22-2011 07:58 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
