Dry Wall Vs Drop Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 04:13 PM   #1
Dry wall vs drop ceiling
We have an uneven basement ceiling. Can a drop ceiling even be done? Or is dry wall the way to go since its not all one level?
grkaras is offline   Reply With Quote
Old 04-28-2013, 05:49 PM   #2
Msradell's Avatar
Rewards Points: 132
It depends on what you mean by uneven, but if it's because you have ducts, beams, or whatever crossing the area is not a big problem at all to use a drop ceiling. It can basically be done anywhere you can put sheetrock. The major advantage of using a drop ceiling is that you can remove a piece to access plumbing and electrical equipment. That obviously is difficult/impossible with sheetrock.
Msradell is offline   Reply With Quote
Old 04-28-2013, 05:49 PM   #3
Too Short? Cut it Again!
Unless you are leaving something out, you should be able to do a drop, tray, etc. ceiling with either drywall or acoustical tile so long as you are within code as far as height at the lowest point of the ceiling.
I assume your floor is level.
Old 04-28-2013, 06:22 PM   #4
Yes the floor is level. We have a spot where the vent had to be taken below a beam so the ceiling would have to be dropped farther in that area. Other than that it's all level.
Old 04-29-2013, 02:36 PM   #5
Rewards Points: 150
Either one.
Drywall will get you maximum height. If your unevenness is only 1/8" here and there, get a pack of drywall shims to bring your joists to level. Test across each few joists w a 4' level to see which ones are shy.
Drop is good if you need to access what's above them. But you lose a few inches in height.
Here's how one of our ceilings looks after drywalling around obstacles...
-mike
SquishyBall is offline   Reply With Quote
Old 04-29-2013, 03:08 PM   #6
This is a bad picture but look at the top. The vent was place below the beam not above so we lost a good foot or two. Drywall is probably best but more expensive and more time :/ also on the other side that you can't see it slopes. So it isn't just a 90 degree angle on that side it is more like a gradual height adjustment like this /
Old 04-29-2013, 09:35 PM   #7
Rewards Points: 5,974
What you will have to do for the slope is build the framing out farther till it is square. If I'm not mistaken (possible) a drop ceiling needs a minimum of 2" of drop.
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 11:25 PM
Unusual Framing for Drop Ceiling? jeffb99 Building & Construction 8 03-23-2013 03:41 PM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 11:57 AM
Where new wall and "popcorn" ceiling meet klein Drywall & Plaster 2 02-04-2010 01:20 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
