Dry Wall Textures - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 12:38 PM   #1
dry wall textures
need help on fixing cealing texture that was wet from leaking roof. Roof has since been replace.I need help on patching same flower type texture.
ffloyd2 is offline   Reply With Quote
Old 03-23-2013, 05:19 PM   #2
Rewards Points: 5,974
Think I know what you mean but really need a pic to be sure.
Old 03-23-2013, 05:26 PM   #3
Rewards Points: 13,270
There's only a couple hundred differant textures and ways to do it so that picture is pretty important.
You about to find out why most of use here think texture should be made to be againt the law.
Near impossible to just "fix" any repairs without it showing.
Nailbags (03-23-2013)
Old 03-25-2013, 10:01 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
But if you're good at texture matching, you can make a pretty good living at it.
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
ToolSeeker (03-25-2013)
wall and ceiling textures crankbait09 Drywall & Plaster 4 07-27-2012 03:02 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
