Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-21-2011, 12:17 PM   #1
Dry wall replacement of plaster walls
We recently had a major fire in our home. I'm working with the insurance who has written the estimate to replace the all plaster walls with plaster, but he also said it would be cheaper to replace it with dry wall and that's OK. I wonder what the cost difference would be? For example, in one room there is 524.19 sf of 2 coat plaster over gypsum core blueboard (1/2 in). What would it cost to drywall that portion?
nlkoebel is offline   Reply With Quote
Old 12-21-2011, 12:36 PM   #2
Tileguy
Bud Cline's Avatar
Ask a local contractor or better yet ask your insurance adjuster. You can't get any accurate information from a place like this. The cost estimate needs to come from your local area.
Old 12-21-2011, 01:37 PM   #3
ltd
imho that's what you have insurance for ,if its blue board and skim coat veneer plaster that's what you want it replaced with.
ltd is offline   Reply With Quote
Tiling an outside wall over lathe and plaster and window mkjeld Building & Construction 8 10-28-2010 07:48 AM
Plaster walls diybev Drywall & Plaster 1 08-31-2010 10:42 PM
Plaster over Concrete Sheet Wall? bk412 Drywall & Plaster 1 06-17-2010 10:10 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
