Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-19-2012, 01:47 AM   #1
Dry Wall Over Tile?
Trying to figure out what I'm going to do. I have been given the task to remodel the bathrooms in my church. Currently I have tile over concrete. We don't want to go to the expense of replacing the tile but no one likes the look of it. It has been suggested to glue dry wall directly to the tile. In the back of my mind that seems like poor craftsmanship. Not to mention the many other problems that come with adding thickness to the walls and shrinking the room. The stalls won't fit and the plumbing will need to be extended. Also the tile only goes 5ft up the wall. I was thinking about putting a shelf with some nice trim to hide the new ledge. I hope to get some good feed back, weather to go ahead and glue the dry wall or something else. Thanks.
Francik is offline   Reply With Quote
Old 12-19-2012, 03:52 AM   #2
Dry Wall Over Tile?
What about removing the tile altogether? Then cleaning up walls and paint if in good condition, maybe stucco or something if not very smooth underneath? Not an expert (obviously), maybe others will chime in
mterry is offline   Reply With Quote
Old 12-19-2012, 08:08 PM   #3
Dry Wall Over Tile?
Door jambs will also need to be extended.
Someone on another forum said he has glued directly to tile....recommends roughening the face of the tile by scoring or grinding, then applying flexbon thinset. Finally, wedging wood between walls, until it sets.
With all the grinding involved, it probably wouldn't be much more work to instead pull the old tile off.
Seattle2k is offline   Reply With Quote
Old 12-19-2012, 08:30 PM   #4
Dry Wall Over Tile?
You may get by with removing the tile and thin set then glue 1/4" drywall to the concrete by removing the tile and thin set the 1/4" drywall may work with out having to change everything. The part I'm not sure about is gluing the drywall to cement.
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 04:16 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 01:01 AM
