Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-16-2012, 09:34 PM   #1
Dry wall, joint compound, Paint
We had a room drywalled and joint compound was used. The compound was sanded as well. We primed the wall as directed but when we painted the walls, you can see everywhere the joint compound was used. How can we fix this?
Bwstump is offline   Reply With Quote
Old 06-16-2012, 10:20 PM   #2
See it as in... Different color? Or rough/raised texture? If the latter it needs to be sanded again. I would also use flat paint as the glossier finishes tend to show more flaws.
TSGR is offline   Reply With Quote
Old 06-16-2012, 10:59 PM   #3
It's raised up. Also, I've noticed that it doesn't seem that the dry wall is even either.
Old 06-19-2012, 05:50 PM   #4
If the joints show, I would call the contractor back out to fix it.
Seattle2k is offline   Reply With Quote
Old 06-20-2012, 12:20 AM   #5
Moderator
May need to: http://literature.usg.com/pdf/J510.pdf
Prevent photographing: http://books.google.com/books?id=lO8...exture&f=false
Or he never achieved the correct level finish for the location/paint application; http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Clothes taking longer to dry?
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
dots in joint compound insearch Painting 2 06-01-2011 10:44 PM
preperation to paint after wall/ P removed deck hand Painting 4 12-06-2009 01:33 PM
Re-doing Spackle mpedrummer Remodeling 4 08-12-2008 04:52 AM
