Drwall/Plaster Integration In 1956 Kitchen And...... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-04-2014, 10:54 PM   #1
Rewards Points: 79
Drwall/Plaster integration in 1956 kitchen and......
Hi Every1,
I had a great experience with my first HUGE project through this forum. Now comes a small one but just as important.
I'm doing a pass through window/bar for a friend of mine on a kitchen in southern California.
Now the whole place is done in thick plaster and cement board under. That's been removed on two side of the kitchen wall and and framed out then slapped with two pieces of drywall together that approximate the thickness of the plaster. I'm near the area where i will have to figure out how to best seam the two and because of the shelving unit next to corner bead, I can't just take out that bead. I NEED to find a way to integrate that corner bead (?). My Uncle, a GC mentioned splicing the end of the new drywall but i've only done drywall once or twice and i had someone else to the taping and mudding.
I plan on creating a clean line as possible by chipping down the plaster where the corner stud meets the header with an old chisel. See pic.
Any help or advice would be appreciated. I'm basically looking for hints on the few seam that will have plaster on one side and drywall on the other.
http://www.flickr.com/photos/4775275...n/photostream/
lionscourt is offline   Reply With Quote
Old 05-04-2014, 11:28 PM   #2
Rewards Points: 79
And as the side wall and ceiling will still be plaster, what kind of tape should i use?? Mesh or Paper??
Old 10-14-2014, 06:56 PM   #3
Rewards Points: 79
Finished......
Beginning
Refinished and repainted cabs....granite countertop
Old 10-14-2014, 06:57 PM   #4
Rewards Points: 79
Pass through
The Following User Says Thank You to lionscourt For This Useful Post:
ToolSeeker (10-15-2014)
Old 10-14-2014, 07:25 PM   #5
Rewards Points: 1,322
This is the first I've seen this DIY project. Beautiful work.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
lionscourt (10-14-2014)
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 10:51 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
